This is an interesting thread to me since OP has the same number of gallons I do. If starting with no chlorine in the pool at all, is 1 gallon really enough to get to 5 ppm? I'll be doing a baqua to chlorine conversion and so I know I need to get to 15 initially. No idea how much liquid chlorine that will take - have to start working with Pool Math.I would go by whatever the Pool Math app says to add 5 ppm of chlorine. A gallon is probably more than 5 ppm for your size pool, but I don’t see any harm in adding that much. For the CYA, I would be conservative and only add 20 ppm worth.
You can test for chlorine 30 minutes after adding, assuming the pump has been running to circulate the water. With stabilizer (CYA), I would run the test a day or two later. That takes a longer time make its way through for whatever reason.
MOD Note: Moved from here Need to know what to start with.
