- Jul 15, 2012
- 604
- Plaster
- Hayward Aqua Rite (T-15)
My hot tub was going from 3600 ppm to 3000 ppm salt every two days, so I knew I had a leak. I have identified two problem areas so far: (1) the top of one of the two pumps for the jets; and (2) the bottom of my Hayward C500 cartridge filter. Photos attached.
The pump spills out significant water when it runs - I believe I need to replace the fitting that screws into the top of the pump (Hayward Superpump). I am not sure how much water leaks from the filter though - seems minimal. As best I can tell it is leaking from the plug at the bottom. The piece looks to have deteriorated and my guess is that I should replace it. The filter itself was either 2000 or 2011 vintage ( I think the former) based on when the house was built and when pool equipment was renovated.
Is the plug something I can buy and replace? I can google part CX250Z14A for my Hayward C500 filter, which is pretty cheap (less than $10), but is this likely to solve my problem?
As for the top of the pump, I removed the fitting and will try to re-attach using plaits-joing stick or some other PVC pipe dope product. The threads do not look so bad on the fitting so its worth trying to re-use. There is still deteriorated teflon tape on the pump where the fitting attaches - not sure how best to remove.
Thanks in advance.
Thanks in advance.
