Hello, I have 2 main issues.
I have a Summer Waves 14ft x42 in pool. This is the 4th summer and we are trying to limp along as it is hard to fine pools affordably. First summer the basic pump died and I replaced with a intex 2500 GPH pump.
1. It took some interesting plumbing of the new lines to the old, but it worked great for 2 summers with no leaking. The hoses started leaking coming out of the original pump housing and into the reducer that is on the plunger valve connected to the pump.
I am not sure if I need to use some sort of pvc hardline to set stop the leaks.
2. The pump seems to be struggling and I can’t tell if t is from the water leaks or if the pump is slowly dying. I have not had enough pressure coming out of the water jetting back in to run my Intex pool vacuum and not enough suction to use the original vacuum.
Thanks for any input.
