Hello! After a long SLAM turning first my pool from a swamp to crystal clear, I finally felt the stress of battling my pool release. A week later, that stress flooded back as my pool had sprung a leak.
I found that the water was exiting at the bottom of the frame, and it just so happened to be under the pallet my pump system has been sitting on. I got some goggles, and found a small hole, and a few small tears throughout the liner along the wall. I patched everything I could find through several slow laps around the pool looking up and down.
The water coming out of the frame has definitely slowed down, and I’m assuming it takes some time for water between the liner and wall from before I patched it to get out, but now that I’ve patched all I can find I’m not sure what to do next. I should say, the water coming out at the bottom fills a little puddle a couple feet wide and maybe an inch or two deep, where the pallet holding my pump system was before I moved it. I used a shovel to move the water, and it slowly filled back up, so that’s my way of checking if it’s still leaking I guess.
I know the liner is 4 years old (as is the pool entirely), though I just bought the house in December, so I don’t know how good the care of everything was in its first few years.
The other concern I have besides the leak is that leaving my pump system not hooked up is obviously not good. Should I raise the water level back up anyway, and keep it going so I can properly keep the pool clean despite the leak? Or should I leave it because the water doesn’t matter if it’s e
More info:
I thought it was the filter system at first, so I let the water get below the skimmer box to see, but it kept going down a little. I inspected the whole pump and filter system many times, h it couldn’t find any issues, so I disconnected it all, and moved it in my garage for now.
After moving everything, I found that the leak was coming out of the bottom of the frame of the pool.
Lastly, and I’m not looking for any sympathy at all, but want to provide the info on my situation, my wife broke her arm this weekend, and I am at the end of my rope between stressing about that, and how we’re going to take care of our 7 month old with me needing to work (from home, luckily), and the pool slowly leaking into our yard. Until our tax return comes (our situation is complicated this year, and the IRS is super behind) I can’t really afford to just buy a new liner or anything major right now. COVID times have been brutal.
More info:
