Leaking in Texas - need help diagnosing
ateam
Active member
Jul 8, 2015
43
San Antonio, TX
Everything was going fine until the power went out.
Now my pool is half empty and I’m not even really sure where it is leaking from.
It’s finally starting to warm up and clear up so I want to try to figure out what needs fixed. I don’t have a regular pool guy since I usually do all my own repairs and maintenance (thanks to tfp), but worried this may be beyond my skill set.
Here are some pics, where should I start?
DBB1D3BA-081A-4ACC-8909-9F33E504A30B.jpeg5C04DB40-FCD8-4B10-A96E-6B599073F463.jpeg11411AD6-4D68-45F5-AC61-FF5C250C3DDB.jpeg37A2E9F3-2180-414F-90A9-DEE05C0828E7.jpeg
ateam
Active member
Jul 8, 2015
43
San Antonio, TX
Here is the pool
Jimrahbe
22,612
Bedford, TX
A,
I think the first thing you want to do is figure out if the problem is at your equipment pad or not.
Since the pool is only half full, you either need to fill it back up or make sure you are sucking water from just your main drain. Turn the pump on and inspect the equipment pad and see if you can see any leaks.. To drain half a pool the leak should be very obvious.
Since you have 4 pumps, you might want to run them one at a time to see what happens..
Let us know what you find,
Reactions: ateam
ateam
Active member
Jul 8, 2015
43
San Antonio, TX
I’m trying to let everything dry out. The roof also drips on the equipment, so everything has been wet. Hard to find a source.
ateam
Active member
Jul 8, 2015
43
San Antonio, TX
When it was leaking everything was covered in snow and ice, so I couldn’t really find anything obvious.
mknauss
43,640
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
That is 10000 gallons or more of water. It would result in more than a wet equipment pad.
Reactions: ateam
ateam
Active member
Jul 8, 2015
43
San Antonio, TX
It leaked out over the course of 2-3 days under the snow, so it’s all run off now. My equipment is below the waterlevel and it seems that it emptied to my middle drain level that feeds my waterfall pumps, so I’m guessing that is the issue.
Jimrahbe
22,612
Bedford, TX
A,
You will need to fill it up at least above the waterfall intakes and see what happens.
While you could have some kind of underground leak, the most likely problem would be a broken line or valve at the equipment pad..
Reactions: ateam
ateam
Active member
Jul 8, 2015
43
San Antonio, TX
3 out of 4 pumps are good. I think the 4th is still frozen. It makes a loud noise when I try to start it and no water movement. I’ll try it again tomorrow to see if It is finally thawed out.
ateam
Active member
Jul 8, 2015
43
San Antonio, TX
Here is a video.
ateam
Active member
Jul 8, 2015
43
San Antonio, TX
The body of the pump is cracked. Can I replace just the body, or do I need to replace the whole pump?
Do these iCloud links work for video?
mknauss
43,640
Laughlin, NV
Fiberglass
Most of use are not real keen on clicking on blind links in a post. Prefer that you post pictures via the TFP server.
If the wet end is what is effected, then it normally can be replaced. Please update your signature with what pool equipment you have (details help).
ateam
Active member
Jul 8, 2015
43
San Antonio, TX
Gotcha, here is a screenshot of the video. This pump is a Pentair Whisperflo. F97F1126-6619-467D-8162-D639601DD5E3.jpeg
mknauss
43,640
Laughlin, NV
Fiberglass
Reactions: ateam
