Leak repair and pressure testing
Settleces
Active member
Aug 23, 2019
29
Hamilton, ontario
Hey guys!! So we got our huge leak fixed. We were losing aprox 350 gallons a day! After he dug deep and fixed it, he did a pressure test. He told my father (I was at work)
“In one hour, I set it to 16 psi, and it dropped to 15.5, nothing to worry about”
To me.... that’s a failed pressure test. But I have no idea what criteria goes into that. Maybe there is an acceptable amount of pressure loss?
Just wondering what you guys think about pressure testing
Photos added just for the heck of it
4B99F67E-C4E2-4867-A8E4-9FFA0A5D6909.jpeg73E582CD-CD4D-4D13-9B83-3DF522D548C1.jpeg32860276-EAEC-4F46-B8E0-DF79EA9D7A40.jpeg
Texas Splash
Someone like @jimmythegreek can confirm, but it is generally true that ideally there should be no change in pressure during a test. It should hold. However one consideration "might" be their testing equipment connection. If there was a small leak at their gauge or manifold fitting for example. If the repair area it still open, try spraying some soapy water on it and look for air bubbles.
jimmythegreek
In The Industry
Aug 10, 2017
2,744
Morris Cnty NJ
1 hour isn't long enough to really get a confirmed test but a half pound is nothing. Ambient air temp can change readings amd when using compressed air it can condense and fluctuate the guage. Soapy water is a good test it's used for gas lines on every job
Settleces
Active member
Aug 23, 2019
29
Hamilton, ontario
Thanks for the info!
The repair spot wouldn’t be our concern for leaks... the entire original plumbing is our concern. We’ve had two leaks in different areas in the return lines... inevitably more will come. I feel like this pool guy should have offered a quote that included digging and replacing all the plumbing but he had us convinced it was all fine. Then within a month of the job completed the first leak near the shed. Then the winter came and went, we opened the pool with no leak April, May and June. July BAM 1-2 inches a day
sktn77a
1,819
Chapel Hill, NC
PVC plumbing shouldn't leak simply because of age. Now, if you have compression or subsidence damage, that's different. Any reason to believe you might have damage to the plumbing elsewhere (such as rubber pipe with hose clamps like in your seconds image?
