Leak from pvc screw in on top of pump
pflood4150
17
Gold Canyon, AZ
I had to replace sections of pipe but I now have a leak from the connector screw in to the top of pump. During the repait I had to turn the elbow it was connected to by about 45 deg out, ie anti CW, and then back again to its original position. Fortunately part of my repair included a compression slide in so I can take it apart in order to unscrew the leaking fitting.
Need advise please as to whether I should unscrew it and redo it with either teflon tape or pipe dope (maybe both?). OR should I use PC Plumbing epoxy around the joint.
ajw22
16,673
Northern NJ
I am not sure where the leak you describe is. Can you circle it on your pic?
If it is the union going onto the pipe on the top left you definitely don't want to epoxy it together. Did you put Pool Lube on the O ring of the unions?
Bama Rambler
23,937
Unscrew the fitting, clean the internal and external threads and either use teflon paste or t-tape on the threads and reinstall the plumbing. I prefer paste, but T-Tape will work just fine.
As a rule of thumb, any time you have to back-off (turn CCW) a threaded fitting, you should disassemble it and reapply sealant. This is especially true if the sealant is T-Tape.
wireform
In The Industry
Aug 15, 2017
1,216
Spring Valley, NY
Be careful when using pipe dope or silicone lube on PVC. It makes a better water tight seal but you loose feel for when to stop and can break the fittings very fast.
