leak between skimmer and pump
bzbmom
6
VA Beach VA
When I run my pump, water leaks out between the skimmer and the pump (only a few feet from the skimmer) I discovered it when I was mowing my yard and noticed the water puddled around the deck- then realized I was adding in quite a bit more water than normal. It doesn't leak when I'm not running the pump. I've seen the add for fix a leak but before I try it, I wanted to get suggestions. There's a hole where the water is leaking- I'm going to dig further when the rain stops to investigate.
Help! What suggestions do you have?
Thanks!!
Brenda
Older 27,000 gallons plaster in ground with Hayward Sand Filter.
Dirk
6,063
Central California
Keep diggin'! I've pointed others here to a no-dig solution, but the consensus at TFP seems to be: dig it up and do it right (find the leak, replace the faulty pipe or joint). If you can dig without disturbing a concrete deck, which would be costly to replace or patch, then I think you should try to find the hole.
