Leak at skimmer gasket
SSharp
121
Nebraska
Pentair Intellichlor IC-40
I’m pretty certain I have a leak at the skimmer faceplate gasket on my inground vinyl lined pool. We have 2 skimmers , both CMP wide mouth. Installation was with 2 gaskets. (Steel pool wall, skimmer, gasket, vinyl liner , gasket, then face plate.)
The skimmer itself was attached to the steel walls with 4 pan head screws, and I’m wondering if the bottom two are preventing the face plate from evenly clamping the gaskets together.
I’ve been trying to read about different solutions, so open to suggestions. Thinking about cleaning gaskets and maybe a thin layer of silicone and tighten back together? Or is there another solution to ensure adequate/even pressure on the faceplate?
We pressure checked all the lines, and they are ok. We took the skimmer faceplate off and could see evidence of water between the liner and wall.
mknauss
51,246
Laughlin, NV
Fiberglass
Sorry you have not received any responses. Let's give your thread a bump on this Sunday morning to see if some responses are out there.
SSharp
121
Nebraska
An update: used marine grade loctite sealant, pulled the gaskets, cleaned them and put a generous amount all around the vinyl liner, gaskets, and plates. Let cure before filling it back up and based on our gravity drainage pipe off the back end of our lot, we are claiming a win!
