- Nov 15, 2019
- 49
- Plaster
- Pentair Intellichlor IC-60
New here and learning a bunch. Thanks.
I'm hoping you can help. I'm getting what I call big bubbles from one return. With the cover on, they appear from behind the cover but when I took it off, the big bubbles are coming from the return pipe.
They start big like you see and consistent like a bottle submerged under water fire a few minutes. Then trickle up like 3 every 5 seconds. These continue for 10 minutes.
Other important items I've noticed.
1. I'm in Dallas. Did a water leak test with tape by the skimmer. Lost 1.125 inches in 5 days. Temps in the 50 to 60s. Thought that was excessive. I have a spa spillover that steps down like a small step down. 5 steps that are about 2 inches thick leuders slabs. Pool company says that this aeration is the cause of the water loss. I run the pump 4 hours overnight.
This is what got me nervous for sure.
2. Builder asked me to do a bucket test but his warranty guy confirmed I can't just run the pool. Has to overflow the jacuzzi. So we can't rule out aeration I guess.
3. I put some blue dye by the return with the pool off and it slowly ever so slowly seemed to creep up the return. Tried two others and the dye just fell past the return.
4. Based on the skimmer water line and the overflow, I can't get this skimmer past 1/3 full or it will be at the overflow level on the other side of the pool. I was told to keep water level at the base of the overflow plate to one inch below. At one inch below, the water barely trickles into the skimmer.
The pic attached is the water at the base of the overflow.
Any ideas on all of this mess. Water leak, air bubbles, skimmer built to low?
Jim
Jim
