Landscaping suggestions for my pool
ewest0482
3
Colorado Springs, Co
We have landscaping rocks in my backyard. My Intex pool will only be up in the summers, so I have no intention of moving or eliminating my rocks. The area is level , but I want to make sure the pool liner is safe. Any suggestions on what to put underneath? I was going to set down ply wood or sub floor squares , then a tarp and then the pool matting or a foam pad....the pool is the 24x12 Intex ultra xtr. If that helps.
sammckin
407
WV
I have the same pool. If you have smaller size rock I think you would be OK with just the rigid foam insulation, might want to go on the thicker side. Plywood and a thinner foam or mat would probably be fine too. Are you planning to use pavers under your legs? You will definitely want your legs and the pool bottom to be flush on this pool.
Reactions: ewest0482
ewest0482
3
Yes, I'm going to get some pavers, thanks for the help.
Reactions: sammckin
