Recently, I've noticed that my automatic pool cleaner will work great for about the first hour or so when the pump is turned on, but any longer after that it stops moving.
There are three valves, one for the vacuum line, suction, and main drain. The main drain is completely closed, and the auction line partially open. However, adjusting the Valve settings after the kreepy krauly has stopped working has no effect on it.
We have a 2HP Whisperflo pump. Is this a pump problem?
