- Jul 21, 2013
- 52,475
- Plaster
- Pentair Intellichlor IC-60
We can’t tell you if draining is safe for you. You have to decide. We give you the options.
If you have CYA of 160 you can do the 1:1 dilution, get CYA 80 and double it. No reason to go 4X. Really doesn’t matter. Your CYA is so high you need close to a full drain no matter how you measure it.
You are missing that the SLAM Process is not a single dose of chlorine. At your CYA levels your water is unmanageable.
