- May 7, 2013
- 50
- Plaster
- CircuPool Core-55
My plaster was just finished in my refurb November 1, and I wanted to keep the pool open a full 2 months to let the plaster cure. My plaster is pretty well cured, although as you'd expect, the pH keeps rising a bit. But my overall chemistry is pretty much dead on.
In looking through the weather for the next two weeks, the Maryland/DC area is predicted to be mild through late January, and by the beginning of March, the threat of super-cold weather is gone. So that leaves me with a 6 week window of potential cold winter.
The water is pretty much perfect chemistry-wise, I have a pump running 24 hours a day at low speed (800-1200 RPM) along with a generator to keep it running in case of power failures, a retractable cover to keep leaves out, and a propane heater if we get crazy cold weather.
And my thought process is now.... why bother paying someone to close the pool, just let the pump keep the water moving, bump on the heater if the temps get crazy cold. Plus, they pump out half the water I just paid to put in there, which leaves my plaster exposed. I really want to keep that plaster underwater with pH, TA, and CH correct for a year.
So I'm all set to call up the pool company and tell them I don't need them to close on January 10th. Can anyone spot a flaw in my plan?
