Keeping it warm!?
poolnoobgrandma
675
Seminole, FL
So, we just had our first pool day of the season. Ran the heat pump to get us to 88-89 (ahhh)
Highs all week will be in the 80s. We have a solar cover we are now using whenever we aren't in the pool.
What's the best way to keep the pool swim-ready, temp-wise? Run 2 speed pump on low 24/7, or set the timer to turn off when we are done for the evening, and start back up early morning? Or something else?
mknauss
43,967
Laughlin, NV
Unless you need to run the heat pump, turn the pump off. Solar cover on. That will retain the most heat.
poolnoobgrandma
675
Seminole, FL
Thanks! It went from 89 last night to 86 this morning, with the pump off and the "solar cover" (e.g. bubble wrap) on. It will just take the heat pump a little while to get it back up to super comfy again.
PoolGate
6,428
Damascus, MD
I am a little confused what you are looking for. Your heater has a thermostat in it. When the heater is on, does your pump also run? Heaters are designed to be set and forget. Set a temperature you want to maintain and let it do its thing.
poolnoobgrandma
675
Seminole, FL
My pump is on a timer. The heater only runs when the pump is on, not the other way around. I have all Hayward equipment, and Aqualogic automation. If there's a way to do what you suggest, I hope someone will weigh in. Thanks!
PoolGate
6,428
Damascus, MD
I am not sure but I feel like your system is setup wrong, especially if you have automation. For my system calling for heat automatically turns on the pump and I can even set the speed it runs when heat is called for. In addition, my pump continues to run for awhile after the set point is reached and the heater turns off for a cool-down heater period.
