K1000 results higher than FAS/DPD
Smelscifi
Active member
Jan 7, 2020
39
Houston
When I tested my pool today, visually the K1000 looked to be in the 5-10 ppm range. When I checked it using FAS/DPD, it only came out to 3.5 ppm. The discrepancy is pretty troubling to me since I was planning on using the K1000 as my daily test once I got the level below 5 ppm. Any advice?
For reference, CYA tested at 50 ppm- I’m in the process of boosting this up to 80 (sock in the skimmer) which I hear can make the K1000 even less reliable. Is the K1000 just not good for SWG pools? Am I stuck running the FAS/DPD daily/weekly?
ajw22
26,322
Northern NJ
Pentair Intellichlor IC-60
K-1000 chlorine test is basically a binary test telling you if you have chlorine in your pool or not. As you are seeing it is very inaccurate.
Once you get your SWG dialed in you can use the K-1000 to confirm your SWG is still putting out chlorine. But to adjust your SWG up or down by a few ppm you need the FAS-DPD test.
