Just wanted to throw this out there....
PoolNewb2020
297
Lathrop, CA
In my view it's not an issue for the TFP method because the FC levels are kept high enough in relation to CYA that regular shocking is not required.
Now, if you follow the industry standard of 1-3ppm FC, regardless of CYA, then algae is bound to appear and when shocked CCs will be formed.
It's quite similar way of thinking to the pharmaceutical industry, they are more interested in treating the symptoms then addressing the root cause.
mgtfp
380
Melbourne, Australia
If they really are concerned about overchlorination, then they should stop spreading this widespread piece of misinformation that to get rid of chloramines, you have to add 10x the amount in chloramines worth of FC. This is wrong. The 10x rule applies to getting rid of ammonia (measured as ppm Nitrogen).
LGLDSR73
89
Boston
Good points, thank you!
Lyman
LGLDSR73
89
Boston
Thanks for correcting that on the 10X rule! Was not aware of that as being for ammonia.
Best,
Lyman
mgtfp
380
No worries! If you are interested in the chemical background, than have a look at this post from from ChemGeek:
LGLDSR73
89
Boston
Thank you, I will check that out.
Best,
Lyman
