Just used my K-2006 for the first time
squirk
78
Southeast Louisiana
And I have to say that the results are not that far off what what Leslie's reported in my last in-store test.
Not sure if there's a way to display my test results from the app directly into a post, but here they are:
FC 6.0
CC 0.5
pH 7.3
TA 70
CH 240
CYA 40
Temp 84F
CH and pH are a little low, but that CC is right on the cusp of being a problem, yes?
My water is clear, but I have algae forming on the walls. Not mustard or black - just the "normal" green algae. My cartridge filters are overdue for a cleaning, which I am sure is not helping.
SLAM definitely required after cleaning the filters? Or should I clean the filters and try just a normal weekly shock? I still am unsure as to when you need to SLAM vs. weekly shock.
Please and thank you.
mknauss
43,671
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
TFPC does not recommend weekly 'shock'. You maintain your FC based on your CYA, FC/CYA Chart
If you have visible algae, you follow the SLAM Process
