Hi Everyone. First off, I am sorry for the stupid questions. I just switched over to start using our new SWC in our new pool. Our PB suggested to keep it at 60% and run our VSP at 2200 but as a word of info, I am not sure he is super keen on using a VSP because it adds complexity to the mix, which is why I am here to ask some questions. As I understand it, I want to run my pump basically as low as possible in order to keep the flow going on the SWC for maximum efficiency, right? In order to do this, I was going to drop the pump all the way down, run it for 5-10 min and see where the "Flow" light turns off in order to determine the breaking point, then up the speed until it comes back on. Does 5-10 min make sense or should I know sooner/later than 10 min? Also, does my plan make sense? For example, I am currently running my pump at 600 and the flow light is still green. I am not sure if this is a good or bad thing. The 2nd thing I am super confused on is the SWC % number. What exactly does this number represent? Some things I have read online say the SWC is either on or off (making chlorine 100% of the time) no matter what the system % is set to. I doubt this is true but I am not finding much out there. Also, is it better to run the SWC at a higher % and the pump at a lower speed or the other way around? I am totally fine to keep the pumps on 24h a day and design a schedule around everything, I am just trying to understand it all. Ugh! Thanks so much for your help!
