I ordered a Taylor k-2006 test kit but it won’t be here until Monday. I’ve been using the pool master five way (I know it’s not the best) Just fired the pool company that had my levels completely out of whack. I balanced them myself with Muriatic acid and liquid chlorine from the pool store. These numbers that Leslie tested are close to what I tested but not exactly the same. Pinch a penny numbers are way different I know my chlorine is high based on cya is it still safe to swim? Leslie’s says they can tear to ten so not even sure if it is higher than that? I’m going to test in the evenings and add chlorine as needed. I would like to keep my fc around 6. I dosed last night because I didn’t know exactly what my chlorine was and I’m so afraid of algae. Is that reasonable? I’m trying my best to figure out what I am doing I get FULL sun almost all day, no screen. Two kids swimming daily almost all day. Any advice is appreciated. Also with a cya of 40 how often should I be testing that in Florida? Will it go down a lot or hold pretty well. Leslie’s said test twice a month and if I see it dropping add two pucks in a floater weekly to raise it. I have leftover pucks. Thanks so much and I apologize for all the questions.
