4 gallons of acid, two bottles of Jacks Magic magenta stuff, chlorine tabs in skimmers.
Tested water this AM (with TF100 kit). FC2, ph 6.8, TA 110,CH 300.
Any thoughts on numbers? Should I wait for higher ph to swim? Will it come down on its own or should I add borax?
You'll want to do a lot of reading on this site: Pool School, Pool Math.
Related Posts:Pool SurfacesStains in Your PoolHow to Chlorinate Your PoolHow to Level an Above Ground … Read more…
www.troublefreepool.com
pH recommended levels are btwn 7.2 and 7.8 so it needs to come up but with a new build there are guidelines you need to follow. One of the mods will be around to answer that question.
Your FC needs to be higher.
What is your CYA level? In sunny Florida the sun will burn off the chlorine faster than you can put it in.
Using "tabs" will increase your CYA but not fast enough to stop the sun. They also add acid and you don't want any more of that. Switching to liquid chlorine will get you started in getting the numbers in line.
Would you please fill out in your signature all the information about you pool and equipment? The mods will be able to help you easier than having you repeat that information multiple times.
I don't know anything about plaster pools, Jack's Magic but those that do know will get with you soon.
