Just Drained - What to do before filling
Nov 27, 2018
1
#1
Hello!
I bought a house with a pool a few months ago. As suspected, when I tested the CYA, it was off the charts (previous owners relied on a pool service that used tabs... I know, unheard of, right? :p). I did a 50/50 dilution test and found it was around 160. Today I went forward with a complete drain to get that back in order. However, before I drop my hose in the pool and turn my $60 water bill into a $200 one, I wanted to know if you all recommend doing anything while it is empty? I do have a pretty gnarly calcium ring around the water line I was thinking of taking care of (water had a CH of 700ppm before the drain... thanks desert water).
Thanks for any and all tips you may have.
an1vrsy
57
Rancho Santa Margarita, CA
#2
Welcome to TFP! Depending upon your location and ground water tables, an empty pool shell needs to be filled back up with water so as not to be pushed (floated) out of the ground.
Last July, I had the scale deposits under my spillover and water feature, professionally media blasted off. Then I searched online for pool water start up chemicals as that wasn’t included in my contract. That’s how I found TFP and I haven’t looked back since.
