Jet Placement and Water Flow
bonsey
103
PA
I've read a few threads about jet placement and water flow but thought I'd throw this out there and see what thee say. Below is an image of my pool. The red dots indicate return jets and the yellow dot indicates the skimmer. The green dots indicate two bottom drains. The arrows are where my jets are currently pointed and it creates a slow circular flow. It seems to work well and keep the surface clean. Does anyone see any reason to change it up? I also have the skimmer/drain valve set to about 1/4 bottom drain and 3/4 skimmer.
Homebrewale
423
Apex, NC
My jets are set so there is a circulation in the pool. When you fall asleep on a raft, it's like the pool is rotating you like a rotisserie chicken.
Reactions: bonsey
