Hi all, the VS motor that was installed with our pool in 2012 is dead. Started getting noisier and I pulled it apart to check into replacement bearings and found a large crack in the motor casing. We have an Aqualink controller and would like to retain the ability to control the pump speed through the app. Will this work with other motors or does it need to be a Jandy replacement?
Thanks
Thanks
