Jandy valves wires cut?
jmsilhy
Active member
Jul 3, 2019
38
McKinney, Texas
Hi everyone, I'm not sure for what reason somebody cut the lines that run from the Jandy valves to the controller in my new home's pool. A couple of questions, can they be easily replaced/fixed? And 2, why would someone do that other than just being nasty? They weren't chewed by rats or anything, they're clean, diagonal cuts hidden along the lines, probably done before I even got the house...
Thanks!
JamesW
17,431
Should be easy to splice back together. Just make sure that the splices are water tight. Do you have a picture of the wires?
Maybe a weedeater cut the wires?
