Jandy Valves Tech Data, Seals, Dimensions & TDH
Zephyros
24
Southern California
Hi All,
I'm redesigning my equipment pad to retrofit in all new equipment to replace the 20 year old stuff that came with the house we bought last year. I've read how hard it is to get tech data out of some of the vendors so I thought I would share this attachment Jandy emailed me when I called with questions about their valves, it provides dimensions and TDH info.
They did mention something interesting, I asked about installing a check valve before the SWG and the guy told me "don't use ours in a high chemical environment" He said there valve seals just can't handle that much chlorine so close to the SWG. He said it was like how some toilet valves fail when people use chlorine bleach tablets in the tanks. He suggested I use a Hartford loop instead. I'm thinking I may use a Pentair check valve there instead, does anyone know if the seals in the Pentair valves are any more chemical resistant?
Best Regards, Tom
PoolGuyNJ
3,192
South Central NJ
He's right about the loop. While there are chemical resistant checks, they cost $$. Pipe and elbows are safer, far more cost effective, and maintenance free. The cell can be placed in the down side of the loop to save space.
Scott
PoolGuyNJ
3,192
South Central NJ
With a salt cell, I keep the cell height below the heater's manifold. The "U-Turn" at the top should be about 6" above the manifold on the heater.
Scott
Other Threads of Interest
