Jandy valve actuator handle rotating 360
colorfaux
34
austin/tx
#1
Hello,
My spa jandy valve handle is rotating 360 degrees with the filter on and with the filter off. When I discovered the problem the motor was hot to the touch. It is a NeverLube model. It does appear to stick making me think it's a gear problem. All of the connections look good.
Dodger
477
Silicon Valley, CA
#2
What is this valve controlling? Do you mean it is rotating from your automation signal, or manually? If it's over-rotating, it could leave the diverter blocking flow where it's not supposed to.
If it was me, I would not let the actuator run in automatic (flip the switch underneath to the middle/neutral/off position). I would open up the actuator to see why it's not stopping. And I would definitely open up the valve area underneath to make sure the diverter is pointed in a good direction for basic pump/filter operation.
