jandy True clear salt cell generator
MJTP
6
Vero Beach / Fl
Jandy Truclear / Ei
Just had Pool company put in a new jandy true clear salt cell few days ago. Question : aren’t you supposed to be able to see water running thru the cell when it is on ?
Wanted to check before I call them since I really didn’t see any water flowing thru but will double check again .
Txs MJ
It can be difficult to see water flowing if there is no air entrained. However, you should be able to see bubbles coming off the plates if the SWCG is generating.
What does your control panel show?
Hi and thanks,
I checked again today and I do see few bubbles off plate and SWCG shows chlorinating at the percentage it is set to .
MJ
