I recently installed a Jandy SmartJVA control board but haven't been able to get it working right. I've searched the forums a fair amount and haven't found any posts of anyone actually succeeding in making it work as intended.
I'm able to assign the SmartJVA to an Aux, then I select calibrate and it begins calibration. However during calibration the valve only turns from it's current orientation to the opposite - So if it is closed it turns to open - then completes calibration and stays there. I would expect calibration to cause it to make a full cycle - Closed - Open - Closed. But it does not.
IF it has ended in the closed position I am able to incrementally ramp up the flow as intended however if I try to decrease the flow it will not close the valve.
Equipment:
iAqualink Rev T
OneTouch Controller
Jandy SmartJVA control Board
Pentair/Compool Valve Actuator - Actuator Stops are set to only allow it to rotate 90 Degrees, NOT a full 180.
Any Idea guys???
Equipment:
iAqualink Rev T
OneTouch Controller
Any Idea guys???
