Jandy RS Battery Connection
Do not loosen that screw. There should be a standard 9v connector wired to the board. If it isn't there, newer boards use a CR2032 button battery on the front of the board. If you don't have either, there are board repair companies, or live without. Only needed if board loses power. Even then you will only need to reset time and date.
