Jandy pool filter
Vcraighead
1
Elk grove
Hi there,
Took apart pool filter cartridges to clean, everything went great until we noticed it’s still leaking around the band just ever so slightly no even a leak just a very slow drip and also by where you tighten the band. Tried to attach picture,but file is large. Seal is fine and we redid everything by the books three times. We just had out pool installed not even 7 months ago. Can anyone give us any advice? Also learned the hard way to only hand tight the drain plug. Noted. First time pool owners here. Thank you in advance.
zea3
13,072
Houston, Texas
Hi, welcome to TFP! Did you put silicone lube on the o-ring? If you could post a picture of the problem that will help us troubleshoot the issue.
