Jandy NeverLube Valve
Car54
Active member
May 19, 2020
25
Tampa
Hello all - love this forum - you guys are awesome!
Just installed Jandy valves on my vacuum side about a month ago. I keep finding that they're getting full of grit when you turn them. I've opened them up once before and cleaned them out and they're starting to show some wear on the seals. Why's this happening and how can I stop it? TIA!
mknauss
32,643
Laughlin, NV
To keep larger particles from reaching your valves and pump, try using skimmer socks. Some use hairnets and purchase them in bulk from Amazon. Search the forum on them.
Car54
Active member
May 19, 2020
25
Tampa
Thanks! I'll get some ordered. My other battle is getting a good skim on my new VS pump, finding that right RPM that gets it done.
mknauss
32,643
Laughlin, NV
Continuous use of a spa spillover drives your pH up. Programming it to run for 30 minutes or so twice a day should be sufficient to keep it chlorinated.
And skimming is best using the returns, not the spillover.
Car54
Active member
May 19, 2020
25
Tampa
Funny - I was just in the process of modifying this.
I’m now trying 6-8am 3000rpm, 8am-sunset 1500rpm, sunset for 2 hours 2500 with spillover, 10-midnight 1500rpm.
Car54
Active member
May 19, 2020
25
Tampa
Every pool is different, but normally you can find a rpm that skims well and stay at that.
Are you saying find the RPM that the skimmer pulls and holds dirt down and never go below that RPM?
Back to original topic for a sec - how am I getting grit in the skimmer valve? This should be sinking to the bottom. Does this mean I have a leak? I'm getting some bubbles when the pump is full speed.
mknauss
32,643
Laughlin, NV
Not quite sure what you mean in 'holds dirt down'. Find the pump rpm that skims the floating debris from the pool surface. That would be the minimum rpm to run the pump.
By grit if you mean dirt - then you need to investigate. A suction side leak (bubbles) usually is from the pump basket lid gasket or some other seal on the suction side. Dirt getting into the suction side is concerning.
Car54
Active member
May 19, 2020
25
Tampa
I think I know why I'm getting grit on these valves. When the pump is shut off, water from the straining basket flows backwards through the valves and I'm thinking it's getting caught on the partially opened valves and closed valves...when the valves are reopened, the grit is resting on the plate and gets pulled into the housing. I followed the in and out...but perhaps in should be on the top.
mknauss
32,643
Laughlin, NV
You should not get backflow like that. You most likely have a suction side air leak and air is gathering in your filter (what type of filter do you have? Please add to signature) and when the pump turns off the air expands and forces water back through the pump.
Car54
Active member
May 19, 2020
25
Tampa
I'm going to go clean it out right now and take some pics....I believe it's pool finish (tiny pebble sheen pebbles). It was redone last year.
Car54
Active member
May 19, 2020
25
Tampa
It’s pool finish. My valves are below waterline so a lot flows out when I take the valve apart.
mknauss
32,643
Laughlin, NV
If your equipment is below water line, how do you get flow back towards the pool when the pump turns off?
I imagine some of the plaster material got in your suction lines? You might try skimmer socks/hair nets over your skimmer basket to see if that catches anything.
Car54
Active member
May 19, 2020
25
Tampa
Some closure on this. Had Red Rhino out and they found my leak on the main drain line right below the deck surface. I have a pavers on dirt so this explains the small pebbles and the back flowing of water...and the draining down. I'm having the pool remodel company fix the plumbing and the paver company re-lay the pavers.5345ED6C-7CA9-4D82-941B-2675FF45BCA3.jpeg
Car54
Active member
May 19, 2020
25
Tampa
Also a tip! If you find grit in your jandy valves, loosen them so you can move the handle past the stops and spin them 360° and the grit will be displaced.
