I have a Ei Pure running with a Jandy Flo Pro variable speed pump into 17000 gallon pool. The system ran flawlessly last year and was winterized (Canadian winter!). I descaled the cell with mild muriatic acid.
On opening this spring, the Ei Pure displays a No Flow condition at around 1800 rpm, low speed pumping. The No Flow disappears when I turn the rpm up to around 2400. Last year, 1800 rpm ran perfectly. Since I'm trying to keep the noise level and hydro costs down, what could be the problem? I have back washed, rinsed and the pump/system is well primed.
Help please!
Help please!
