Jandy Diverter Valve Issue?
smudger82
8
Brisbane
Hi all, has any one had any issues with a Jandy Diverter Valve (pictured)? When I select spa mode and the valves automatically move to feed water to the spa only, we are getting a big pressure build up in the outlet of the chlorinating unit (pictured). My pool guy thinks that the valve isn't opening up properly to feed to the spa and is causing pressure. Can't get a local service business to look at it and the pool builder doesn't want to know. Very annoying. Any ideas? TIA
mknauss
43,671
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Take the actuator off and manually move the valve. Does it do the same thing?
mknauss
43,671
Laughlin, NV
Fiberglass
Try the toggle first but I thought you said the valve was not turning appropriately. You can also just completely remove the actuator from the valve, put the valve handle on the valve stem, and manually turn the valve. That will tell you if the valve is OK>
smudger82
8
Brisbane
Thanks. I don't think I described the issue properly. Is it possible for the top part / plate of the value to move to the correct position, but the actual valve underneath doesn't move around to the correct position to block off the correct pipe fully? TIA
mknauss
43,671
Laughlin, NV
Fiberglass
Only if the valve stem is somehow compromised.
Take the actuator off the valve, you unscrew 4 screws. Do not put the screws back in just the valve as it will break the valve body.
Put the handle on the actual valve. Then move the valve to the positions you want. Does the water get correctly diverted?
