Jandy Automation- changing pump speed from control panel
freed1b
7
Ontario
Hi - I have a Jandy IAqualink automation and a Jandy variable speed pump. I know I can change the pump speed from the app, but was wondering is their a way change the speed from the control panel/power center - in case the app wasn't working? Thanks in advance for your help
ajw22
28,469
Northern NJ
Pentair Intellichlor IC-60
Do you have the All Button or One Touch control panels or only the app?
ajw22
28,469
Northern NJ
Then that is the only way you can change pump speeds.
freed1b
7
Ontario
ajw22 thanks for the quick reply..... seems like an oversight since if the app, pda or wall control unit is not working - one is stuck and cant increase pump speed to vacuum the pool for example.
ajw22
28,469
Northern NJ
They expect you to have one wired panel in addition to the app.
