Seems like I'm finding issue after issue after I resurrect my pool from a few years of neglect.....
I have a weird connectivity issue between my Jandy Aquapure and Aqualink. Or maybe this is a total issue on the Aquapure side of things. First off, the Aquapure doesn't seem to retain it's setting for chlorine production. I can set it to 30/40/70/80%....anything.....and it doesn't seem to retain that setting overnight, when powered off, etc. When it powers up, it's set at 0%.
Also, when Aquapure and Aqualink are connected together via the 4-pin header, I can not adjust chlorine production rate from the front panel on the Aquapure. It just stays at zero.
Also also, through the iAqualink app, I can set chlorine production rate , but it doesn't change on the Aquapure. I can see the Aquapure is connected, can read salt concentration, but that is all.
If I disconnect the Aquapure and Aqualink, then I can set chlorine production from the front panel on the Aquapure.....but it doesn't retain that setting.
It would seem like the main board on the Aquapure is bad in some way, but I'm not 100% convinced. Nothing I've found on line or in the manuals is similar to the conditions I am seeing.
Thanks in advance for the help.
