Jandy Actuator Valve
edima302
Active member
Jun 13, 2017
31
Marlboro New Jersey
Hi all,
I just replaced my Jandy Actuator (model 2444) and am having trouble getting the gears to line up. I have the switch set to the On 1 position and the valve is turning as far right as possible while on pool mode. How do I get it to stop at a 90 degree angle so that the spa runs properly (allowing the overflow feature). The pic below shows the correct position of the new actuator (pic on the left). I set it manually and have the toggle switch on off currently. Also I have tried to reengage the valve my loosening the handle and pressing down the center piece.. can’t get it to engage to the 90 degree position. Thanks
