Well just installed a new 2-port never lube valve and it is leaking at the seam between top cover and body. Replaced the o-ring just to make sure, cleaned it all up to make sure no debris, etc. and it's leaking and spritzing out a lot of water. I checked for cracks, etc. and all seems to be fine. Can never get in touch with Jandy support. Any suggestions? I am using the valve as a heater bypass. May have to replumb and use a ball valve that I originally had that gave me no trouble. Since I was re-doing some plumbing I figured installing a Jandy valve for longevity and repairablity.
