Jacuzzi JVSP 150 electrical draw
farmo83
4
Houston
Hi
I have the above mentioned pump and am trying to find how many amps the pump draws. It's not listed in the owners manual nor have I been able to locate it elsewhere on line. If this avenue fails I will invest in a clamp meter.
farmo83
4
Houston
1.5 hp runs a 240 breaker 20 amp breaker.
The pool it's own a sub panel. I'm trying to see how much load is really on the panel as we would like to add a few other lights.
ajw22
8,934
Northern NJ
There should be a data plate on the motor for the amps to be used for load calculations. Actual amps used will vary with pump speed.
