Hello,
I'm new here and looking for help troubleshooting my 10-12 years old Jacuzzi 270.
The heater won't turn off after it reaches the required temperature. It only stops when the tub goes into watchdog mode (the three dashes"---"), way past the 104 maximum. If I reset the breaker it sometimes fixes the problem for a while, sometimes not.
I've confirmed with another thermometer that the temprature shown on the display is correct.
I've changed that heater about a year ago and it worked fine until now. Not sure if it's relevant, but I also changed the flow switch recently and the circ pump about 2 years ago.
Should I replace the temp sensor anyway even if the temp shown is correct? Or could this be a control board issue ?
Any help would be greatly appreciated, thanks
Max
Max
