I've got a leak...
Jimrahbe
19,169
Bedford, TX
IV,
To really fix it, you are going to have to cut it out and start over, using pump unions..
But... I would at least try to seal the leak with 100% silicone caulk first... What have you got to lose.?
I would turn off the pump, dry it off, coat it with caulk and let it sit 24 hours before turning on the pump again.
Reactions: SerenityIV
sktn77a
1,887
Chapel Hill, NC
Assuming epoxy or silicone doesn't work, you'll need to cut the PVC pipe just after the pump connection and use a new connector (as above). Use a pump union so that, if it continues to leak, you can tighten the connection or use more teflon tape/paste/dope. Just be careful not to overtighten it and crack the pump outlet.
wireform
In The Industry
Aug 15, 2017
1,538
Spring Valley, NY
You can try
Or
