It’s time to play... Name this stain!
Rjdollardlite
17
West Palm Beach, FL
Step up and try your chances - name this stain! Ignore the construction next door. We think the stain is from an iguana or bird - no metal in the pool . Thanks for your help and any insight on best way to clean - and yes, we are trimming the palms that hang over the water today ! image.jpg
ajw22
21,195
Northern NJ
Pentair Intellichlor IC-60
If the stain is organic then putting a trichlor puck on it for a minute or two should lighten or remove it.
To determine if you have an organic stain place a trichlor puck on the stain for a few minutes to see if it lightens or removes the stain. If it does then the stain is organic. To remove organic stains raise the FC up between 60% and 100% of shock level for your CYA, Chlorine / CYA Chart, and brush often, daily if you can.
