Issue updating Intellitouch Firmware from 1.051 to 1.190
ogdento
734
Chico, CA
Hey folks,
I just updated the firmware on an Intellitouch system for a fellow TFP member @riverlvr ... his system had an Indoor Unit at T1.051 (Service/Trainer version), and an outdoor unit at 1.130. I updated both to 1.190.
The problem is that he had 1 VS pump set up - but after updating the firmware, the VS pump had changed to a VF and he is unable to change it back to VS... cycling through the types (VF > VSF > VS) and selecting VS has no affect.
The release notes specify a procedure when updating from a version 1.070 or below to a later version... basically they have you:
- update the indoor firmware
- clear the indoor unit's eeprom and allow it to load programming from the outdoor
- clear the outdoor unit's eeprom and allow it load programming from the indoor
That procedure ensures that you're loading your "old" programming into a device running the updated firmware, and it's supposed to mitigate any update issues. I've done dozens of updates to 1.180 and never seen a VS change to a VF... but I haven't done too many to 1.190 - especially on a system running firmware older than 1.070.
Does anybody know of any issues related to the 1.190 update from older firmware?
Rocket J Squirrel
1,226
Alamo, CA
Isn't there a step missing here, namely update the outdoor firmware?
Anyway, I'm no expert in these systems, as you are. But I know that some devices end up with errors if their firmware is updated and then settings re-loaded from a much older version.
The device I'm most familiar with is home network routers. Many of them will error if a saved configuration file is restored after a major firmware update. For those devices, the best approach is to do a factory reset after updating the firmware and re-enter the configuration by hand. This means you have to write down or capture images of the old settings prior to updating.
ogdento
734
Chico, CA
Squirrel you're absolutely right on all fronts - first, I forgot to add the "update outdoor firmware" step to the list!! I did do that bit though :)
And your router analogy is spot on... I guess it's hard to expect that you won't lose any data when updating a system that is so old.
I just found it interesting that their procedure has worked for all the 1.180 updates I've done (many which were <= 1.070), but not this particular 1.190 update.
