Is this white water mold
Susiejax
55
Fort Wayne, Indiana
#2
Are you using powdered "shock"? I used to use that before switching to the methods recommended on this site. Sometimes, the product would gather together like that on the surface of the water. I don't know the scientific reason for it!
But have you tested your water? My guess is that it is out of balance, causing the flocking effect.
tim5055
10,087
Franklin, NC
#3
What are you using for sanitation? Chlorine of Baqua?
Please edit your signature and add the following information so we can better frame our answers to you.
  • List what test kit you use to test your water
  • The size of your pool in gallons
  • If your pool is an AG (above ground) or IG (in ground)
  • If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
  • The type filter you have (sand, DE, cartridge)
  • If you know, tell us the make and model of your pump and filter.
  • List any other equipment you have: SWG, second pump, etc.
  • Please mention if you fill the pool from a well or are currently on water restrictions
Information in your signature will show up each time you post and it makes advice more accurate as we know what equipment we are dealing with.
