Is this reasonably priced? New pool in Vegas
Nannncywangster
1
Las Vegas
Hello there, I am new to this community and this is my first post! I am hoping to see what you guys think about a quote I received for my pool + spa project, I want to know if it’s fairly priced/ is there any room for negotiation. Please take a look and thank you guys in advance!!
Pool Size-15’x29’ Depth- 3’6”-5’6” Square feet-417
Spa Size-7’x7’Depth-3’6”Square feet-49
Items included in proposal:
• Engineered plans, permits, taxes and lien releases
• Workman’s comp. public liability and property damage insurance
• Complete pool layout prior to excavation for your approval
• Normal excavation and site layout with access
• Engineered steel and shotcrete plans with min. 4500psi mix
• All plumbing Sch.40 PVC with separate main drain, skimmer and vacuum line
• All required electrical service with sub panel time clock and GFI protection
• Over 100 Standard tiles selections
• Equipment pads
• 48’ of 1 ½ inch PE Gas Line for heater
• Hayward Equipment to include
• Vs Omni 950 3hp filter pump
• 1 Skimmer
• 400,000 BTU Heater
• 1ea Color/LED pool light
• 1ea Color/LED spa light
• 1 ea LV Color/LED lights in Wet Deck
• All check valves and 3 way valves
• Hayward Omni Wireless Control using smart devices
• 2 ea valve Actuators
• Independent Vacuum line with Aqua Naut 200 Vacuum.
• Chlorination- Deck Chlorinator
• 1ea Bubbler in wet decks
• Umbrella sleeve in wet deck
• Plaster Finish- White or French Grey
• 6 spa jets with 1 1/2hp air blower
• Spa to be raised 18” with Infinity edgespillway
• Kool Decking- 530 sq ft of sprayed cool decking, with cantilever formed bullnose coping
• Pavers -440 sq ft
• Raised Feature wall with 48” stainless steel sheer descent, operated by Tristar 1HP feature pump
• Freshen landscaping at front yard access
Home Owner responsible for any soil inspections if required for permitting. Also home owner to be responsible for any hard dig/Caliche which requires hammering at $200.00 Per Hr.
this company wants to charge me $67k and I am located in Las Vegas.
RU4Cycling2
38
Edmond, OK
Pool prices vary widely based on location. I’d recommend getting several quotes and speaking with several customers for each of the pool builders. For what it’s worth, that pool would likely be $10-$20k more in my neighborhood in Oklahoma City.
TampaKathy
131
Tampa, FL
I agree with what RU4Cycling2 said, best way to judge is get multiple quotes. I would add, get them as similar as possible, meaning, don't change size or depth or anything major so you can compare apples to apples. I would review this one in detail, is it everything you want...chlorination system, number of lights, equipment size, number of skimmers, decking type, etc. then you'll be able to be more specific with the other PBs. Or you could just see what each PB recommends but it will be harder to compare to each other...but you can go back to them afterwards and ask for changes. Also ask what their payment schedule is when you meet with them and make sure you are ok with it...some front-load it way too much.
LayneeVegas
2
Las Vegas
• Equipment pads
• 1 Skimmer
• Pavers -440 sq ft
Hi there! New to the website. I came across your post as I’m looking for other DIY experiences in Vegas. I received bids from 2 contractors in Vegas recently and the one you received is not far off. I decided to go owner build and will be saving around 30%. Contact me if you want to discuss.
