Is this Clear?
Ribbod
125
Marietta/ga
After seeing a few posts on "Clear Pools", I dont know If Im there yet.. Been Slamming for 3 weeks and performing OCLT test tonight, but not sure if I'm "there" yet...
Msch99
688
Verona, MO
Nice job maintaining ~16 ppm for the slam! Looks like CC was zero to day. I bet you are good!
Does the water seem cloudy, is that your concern? If it is staying cloudy, check your lights/niches/ladder supports etc for a hidden source of algae.
Reactions: Ribbod
bmoreswim
Platinum Supporter
6,168
Central MD
Ha, if you had to think about asking, it probably isn’t clear. :) Clear looks like there is no water in the pool when it’s still. Seeing the screw head on the main drains. Telling head or tails on a quarter in the deep end. You get the picture. You’ll get so spoiled once it’s done (and clear) you’ll pity the algae that dares mess with you.
Reactions: Ribbod and NorCalX
Ribbod
125
Marietta/ga
Thank you :) I passed the OCLT test this morning, 0 CC, I can see the quarter at the bottom of the deep end but at 9 feet, I can't tell if its heads or tails.. I have no stairs, no lights, no main drain only a metal ladder and there are no issues there...
I think I'm going to to turn on SWG and let FC drift down, adjust CYA to 70-80 and maintain FC on the higher end and hopefully it will continue to clear- I.m sure PH will need to be adjusted as well.
Reactions: Msch99
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
33,852
That's a good plan. Run your pump 24/7 for another day or so. Added filtration will often get you crystal clear.
Reactions: Ribbod
