Is this a good salt?
Stephs2125
66
SE Michigan
CircuPool RJ-60 Plus
Hello from still chilly Michigan - I am scheduled to have my SWG installed next week (with pool opening to follow in early May). I want to be sure I am buying a good quality salt product...is this sufficient? Or do you recommend something different?
Thanks!
Stephanie
Stephs2125
66
SE Michigan
Follow up question...assuming I am starting from zero (I know even tap water has some salt but assuming).., my pool is approx. 36k gallons so I would need to add 23 bags of salt to reach 3000 ppm? I used the 'effects of adding' feature in Pool Math and it said each 40 lb bag would raise salt by 133. Again assuming I am at zero, 3000/133 = 22.55 s0 23 bags correct? Am I using/understanding the calculator properly?
I plan to actually test the salinity of my water before making final calculations but it's still under a safety cover right now so I cannot get to the water just yet - just trying to be sure I understand how to use the app.
Newdude
17,281
NY
Test first as you'll be surprised how much you have already. Make sure to mix for a few days before said baseline test.
For poolmath go to settings and click track salt. Then it's a parameter on the regular page. Enter 650-3300 (or whatevs) and it will say add X bags.
Reactions: Stephs2125
ballyscanlon
Active member
May 15, 2018
27
Pound Ridge/NY
Pentair Intellichlor IC-60
I would like to piggyback on to this question if I may?
That specific salt that was referenced in the original question, is $2 cheaper than the same brand's 'pool salt'. Is there a difference in the pool versio in the granularity that makes it better for dissolving? I too and switching to SWG this summer and have over 1000ibs of salt to add.
thanks
john
magiteck
850
Neenah, Wisconsin
Solaxx (Saltron) Reliant / Purechlor R5
thanks
john
The “pool salt” is more finely ground and therefore should dissolve faster, but the solar salt dissolves quick enough anyway that it’s really a non issue.
If it were me, I’d save the $50 and buy the solar salt. :)
Also, adding “pool” to the name of any chemical makes it immediately more expensive.
