I need help and honestly I'm rather overwhelmed.
We've been trying to research and figure out this issue for a couple days now and we do not know a lot about pools. We've had green algae for months. Started last year. We barely used the pool because we were constantly fighting the algae. We believed it to be because of the filter. We had a cartridge filter and replaced it beginning of least season. Didn't fix the issue. We had to remove it and spray it 2-3 times a day. This year we decided to stop messing with that filer (the housing was broken anyway and we could barely get it on or off) so we decided to go with a sand filter. We installed the sand filter and that's when I noticed the lights on the Pentair Intellichlor ic20 weren't working. The salt level lights were flashing red, none of the flow lights were lit, and initially the chlorine output lights were cycling but now are off.
When we went to purchase sand for the filter, we did have the water tested and we were told that the cell wasn't producing chlorine at all. It was recommended to clean the cell, give a couple days to do its thing, and then it would be fine.
My question is-it seems to me that the cell or some component of the cell is bad. How do I figure out what component is bad before I spend hundreds of dollars on replacing the cell or buying component parts to have to turn around and replace the cell anyway. This cell is 2 years and 1 month old. We have cleaned it. The fuse located on the power box is fine. The cable to the power box is secure and not damaged.
Appreciate y'alls help.
