This am I went out early to empty the skimmer as usual. I noticed the pump basket had a lot more tree debris than usual and I know I needed to empty it. But figured I would do it later after work.
I had a bunch of meetings today and when I got out of them at 2:30 I noticed the pump wasn’t on! 😳 I went to check and I tried getting it to click or make a noise nothing not even a hum.
I tested the gfi and it was fine. But noticed the pump was very hot. So I quickly emptied the pump basket and cleaned it. Turned the switch on and it hummed now but isn’t pumping.
I let it rest for another 30 mins then just went out and tried it again and it’s only humming. I know it’s getting power now but it’s not pumping.
Anything else I should try? Am I going to have to get a new pump?
Thanks.
Thanks.
