Is muriatic acid essential?
gorocket1981
159
Montreal, Canada
Really? That can destroy my heater? OMG!! :cry:
Since I am North and I have to lower the water level of the pool in Autumn, does the dilution with the new water reduce the damage by not over accumulating the sulfates all year?
I did calculations. It would be a bit cheaper using the Muriatic Acid as some people said.
Suppose I get Muriatic Acid in a plastic bottle and like you said I store the bottle in a trash can, can the trash can be placed not far from the pool or the equipment? Will the potential fumes will still corrode the equipment or the pool?
@mknauss, my question was "lost" in the remaining of the thread discussion, but about the dry acid and the Sulfates you were referring to, since I am North and I have to lower the water level of the pool in Autumn, does the dilution with the new water reduce the damage by not over accumulating the sulfates all year? (question in bold in my previous post) Can this limit the damage?
Thanks!
gorocket1981
159
Montreal, Canada
In theory that should reduce the build up of sulfates. Time will tell if it harms the heater.
Ok thanks. I'll try to battle my fear of Muriatic Acid and see how I could safely handle this based on other's comments and suggestions.
If the trash can with the MA inside is placed near the pool and the equipment, will the fumes corrodes or harm everything around?
Thanks!
mknauss
32,540
Laughlin, NV
Whether it is a plastic 5 gallon bucket with lid or a small trash can with lid, store the 1 gallon (or ? liter) bottle of MA in it. You can put it anywhere you like, just not in a confined space. As long as it is outside, and metal is not directly next to it, there will be no effect to anything.
Reactions: gorocket1981
